I know these cells produce gas, but we’re talking tiny bubbles, right? There shouldn’t be any larger air pockets, should there?
70 degrees seems higher than any of the other models. My RJ60 produces chlorine down in the high 50’s. Haven’t tried it any colder than that though.OMG!! I’m beyond frustrated!
So, I received the new flow switch, and purchased and assembled a new shed so I have more room. Before I started cutting pipes, I called DSP again to verify how far away from my pump the flow switch must be and how high my risers should raise the cell above my pump. The DSP guy went through it all with me and said if my flow light is green then all is good. He said my installation was fine. THEN he says, “ your temperature sensor is in the cell on that model, I bet your water is just too cold. If I were you I wouldn’t cut anything until your water temperature is about 70!”
REALLY? Does anyone really know how this thing works?
If I poor hot water without salt, won't the salt light come on because I have diluted the salt too much?If it were to cold the temp light would come on red?? My temp light was off and it was working at 65 degrees... Mine is now at 80 degree water temp and the light is still off... When it was too cold that light was red.... I did not see your temp light as red, it was off also...
We can test this though... Do the hot water bucket without salt and pour it into the skimmer and see if it turns on..
