- Aug 20, 2020
- 7,887
- Plaster
- CircuPool RJ-60
Is the duty cycle turned up to full power? The cell should make chlorine for a bit then turn off for a bit then on again. Kinda grasping at straws.
If it were me, I’d assume I did something wrong on install. I might try another outlet, even one that’s not GFI. I might also try 220V if you have it. Maybe also try two outlets in different branch circuits in case it’s an over current issue.
Is the flow switch installed the right orientation?
