- Aug 20, 2020
- 7,765
- Plaster
- CircuPool RJ-60
They exchanged it no questions asked. So good news. I did discover a different method for chipping that’s goes faster and uses a different bit. The bit flat bit works better for skimming the last bit of plaster off of the gunite. A straight flat bit aiming straight down into the plaster works in that it fractures a larger portion of the plaster and makes it tend to break loose in larger chunks.Yikes! I would think that should easily be exchanged, but I've been wrong before. I can't see that you were using it in a manner that wasn't intended. I've torn up tile with those, but Bosch brand, not Milwaukee, and not ever had any issues like that.
--Jeff
I’m looking at renting one from Quikspray Inc, but doing it myself is still a backup plan. Even renting a pump, I’d need a few other somewhat experienced people helping that I don’t currently have. I’m somewhat hopeful I can find someone I can trust to do the plaster work at a minimum.@Bperry what kind of plaster rig are you looking at using? Man please be careful - if it gets a pack in the hose the pump will easily generate enough pressure to blow the hoses apart violently - a local competitor blew a hose and it whipped and snapped his shin...then did it again about 6 months later to the same leg!
Let me know, I might be able to offer some tips on best practices to make it go smoothly. Diamond-Brite can be tricky to pump.
Good thinking! Get it done and let them help out!So I’ll be leaning on my wallet again to rent a small bucket loader and then have the family grab a bucket and scoop.
I SO hear you!!!! I do not like waiting for other people. They are NOT of the same time line I amin a bit of a holding pattern waiting on someone else. That’s the hardest part for me, as I’m not very patient.
