Battling low chlorine levels all summer
So that would put me at 73 instead of 70 and recommend by TFP is 70-80 so I would be ok then.
73 ppm is fine, but because of the lack of precision of the CYA test, I'm a bit apprehensive to tell you to do it in one dose. The final result is reliant upon the accuracy of your test results and your estimate of the pool volume. If you're
confident in those two factors, dose away.
Pool volume I am confident as I called the builder just last week and got what they say it is which is the 11,250 gallons. The test well you know how that is. I think I will shake this jug up the best I can and put it in in 2-3 treatments. That or just wait till tomorrow and go buy dry stabilizer to use instead of what I have.
Use it and rinse several times to get it all.
I shook it up for about 20 minutes and added 32 ounces. I know there is still going to be stuff at the bottom of the gallon but I figure to be safe I would do it this way test again on Wednesday and see what results I get and add more as needed. Because the CYA test is the only one that is very difficult to do I don’t want to add too much and then have to drain and refill water. Figure it would be better safe than sorry. I am having to add water to the pool every 3-4 days anyway with our already 14 or 15 days of over 100 degree weather. So I will probably end up using the whole gallon as it is but will see.
Set your SWG to produce 4 ppm FC per day. Test and adjust output from there.
Consider upgrading to VS pump in the future.
So maybe I did something wrong here but yesterday my FC was 9.5 when I tested so I went ahead and turned on the SWG and then today my FC was 13 when I tested. Should I turn the SWG back off until the FC drops lower than the 9.5? I set it to do 4ppm and that is exactly what it did today or more since I was at 13 around 5:30 pm today. I have since lowered the % of the SWG to try to get back down? I also pulled a oops and started adding acid to lower PH & TA forgetting that PH is not accurate when FC is above 10ppm that was a waste of acid. Lesson learned.
Turn it down to add 1FC. Your FC will come down slowly. Or you can let it come back down with cell off. Matters not.
When you fire it back up again, do it with 1FC addition and see what that does. You will have to monitor and change your percentage throughout the season.
Reactions: hensler74
As mentioned, no worries. I guess you've created the perfect pool that doesn't require chlorine.:ROFLMAO:
Once you figure out what your daily FC loss, you can set your SWG accordingly. It'll just take a little testing to figure it out. Great job on getting your pool squared away!
I could not have done it without the help of you guys. I really appreciate it.
Well it is me again. Today my FC is 10 and PH is 8 or higher. I should be ok to start adding acid to get the PH as well as lowering the TA which has been holding steady at 110. I know I need to drop the TA to between 60-80. This means I need to lower TA by at least 40 ppm to be in between the recommended and that is about 114 ounces per pool math which would also lower the PH to below 7 if my rough math is correct. From reading here on TFP I can use aeration to raise the PH so would my spillover from the spa be enough to raise this quickly if my spillover runs 9 hours a day. From what I know I cannot control the spill over cause as soon as the pump comes on the spa automatically starts to spillover to the pool so I could run. It longer if needed.
Am I on track or am I over thinking this?
Just don’t want to get myself into trouble this soon after the slam. 😂
You're on it...
Your plan works...it works for me. My fill water has a TA of 130. In summer I'm constantly battling TA and pH rise. I have a spa spillover that I run constantly to aerate. This increases pH and allows me to add MA which controls TA rise. If my TA gets above 80, I start seeing flakes from the SWG (my CH is only 300). Without the daily aeration, my TA would beyond control.
I can't recall if you've checked your fill water TA and CH. Might be a good time...
You may have seen this, but here is the article on Lowering TA:
You are overthinking this.
1) pH test is invalid when FC is >= 10. You really don't know your pH. Let FC come down to 9 and retest pH.
2) Ignore TA unless it is less than 50. Manage your pH and keep it in the 7s. When you reach 8, add muriatic to reduce it to 7.6. Just manage pH.
Maybe...unless you start seeing scale/flakes from the SWG. With those numbers, my pool would flake up like a snow globe. See how things go with normal pH maintenance...
Reactions: PoolStored
At TA 110 and CSI ~.3, maybe... I think if he is diligent with pH testing (often), TA will come down fairly quickly. If he wants to speed that up, reduce pH to 7.2. When it rises to 7.6, reduce to 7.2 again. Monitor TA along the way. When TA gets to about 70, stop forcing pH to 7.2 and let it hover around 7.8 and see how stable it is...
I agree on testing fill water...this could be a culprit!
You're on it...
Fill water TA 120 CH 100
Fill water TA 120 and CH 100
That is not bad...seen some north of 250. Yikes.
I stand by advice in post 94 and 96. Manage your pH, don't chase TA. It will come down over time. Manage your pH between 8 and 7.6. If you really want to push it, do as I said in post 96 and when TA gets to 70, let pH settle where it wants.
Ok I am going to let the FC fall more tomorrow SWG has been off since yesterday when FC went up to 13. Once I get to 9 I will start to test and attic PH and not worry with the TA and hopefully like you said it will gradually come down with the maintenance of the PH. I am going to start test PH daily as recommended here until I can learn to get the feel for it. I believe my issue is I am try to rush it because I thought I could start trying to regulate PH since FC was a 10 today. Once I can get FC down some more to slowly start to adjust my SWG I will start to look for flaking as Rancho pointed out.
