So I've come into this older Aber model 180 tub. Sat out in the rain for several months, with the open control panel facing upward. Dried it out for a couple days (under cover, warm air), then connected to power. Pops the breaker instantly when one leg of the 220 source is connected: unplug both, breaker is fine; connect one, breaker is fine; connect the other, snap!
We disconnected the heater, but it still pops, so that should rule that out.
I've sourced a replacement board (Balboa Lite Leader) online, around $130-$140, but before I pull the trigger on that, does anyone have any tips for testing these and maybe finding the bad component? The relays are open coil and probably soaked through and done forever, but those CAN be replaced individually.
Also, I figure to test the heater... should be able to check resistance across its terminals. Any idea what it should read?
