Hello, new to the forum. I have a pool going in right now. I have the following already installed (all Jandy branded):
- Jandy VSFloPro — VSFHP130DVS — 1.3 HP pump
- TruClear 11k — salt chlorinator kit
- CS Series cartridge filter — CS200
- 3x 12w LED Nichless light, model JLU4C12W100
- blower (the guy forgot it, that should happen today)
The pool is quite small compared to a lot of you --- 5000 gallons give or take. It never freezes where I am. There are also permitting issues where I am, so the pad you see will potentially not be the final install location (certainly not final pad size). I am comfortable with wiring and plumbing but at a pretty busy time in life. I have a Home Assistant instance running and can usually bend that to my will (usually).
The install is ongoing (my yard is a disaster). The guy doing the equipment install is friendly enough, there is a bit of a language barrier (my spanish gets me taco's and a beer and that's it). He did label the lines for me which I appreciate. I have not pressed to test yet if they would sell me equipment on the side. The overall pool installer doesn't seem to care much about specific equipment and initial probing about automation lead to a simple, "welllllll, you can make all kinds of fancy automation and I think it's another $5k, those guys can work that out but it isn't that hard and you don't need to do that." I respect his opinion, but i'm also a big fan of automation.
Issue 1: I will be putting in a heater/chiller on this installation -- looks like Jandy sells a VersaTemp heat pump type unit -- I have 220 to the yard, this doesn't seem hard. Trying to figure out how to buy that heat pump for a self install later has proved a bit of a challenge. Does Jandy have a policy against them selling me this gear for a self install? Is there a secret code to get around that?
Issue 2: I am considering an "auto acid dumper via tank and peristaltic pump" situation. I haven't found Jandy's turnkey solution to that yet but I feel like something like that probably already exists. There are a fair number of folks who have home-brewed this up, I'm not sure I'm that smart or have that kind of time. Is this worth it to either home-brew something here or just use Jandy's solution --- or is this just, "It's not that hard man, do the testing, add what needs added, don't overthink it"?
Issue 3: I am considering a Jandy RS Aqualink setup but couldn't be more confused on what exactly it takes to GET that set up. All my equipment says "Aqualink Compatible" on the various boxes and manuals but I'm having a devil of a time finding specific installation instructions. I did go through the Aqualink Wiki here and while helpful, I still don't have a grasp of exactly what equipment is needed to get that all going. I sort of get the feeling that Jandy doesn't want me to know, that they want a "qualified installer" to do that. Which I might do -- but I would like to know specific equipment requirements, performance expectations and cost. (and I am interested in self install if I can just get all the kit and have a solid enough grasp of what exactly needs done). Jandy seems to want it's own PowerCenter (which seems an overpriced breaker box, with another side for low voltage and relays) -- then I am pretty confused about the most recent version of a control panel (one touch, buttons, tablet) --- and there is a wifi antenna for another $350 (e-bay). I am pretty confused with all that. Can't seem to source the valve actuators -- seems like Jandy only sells the relays and not much specific info on that either. Getting a handle on all that's involved here would help me make a solid decision on if I can get the parts (or parts that will work fine) and do the install myself --- or, if it's worth it to let the pool equipment company do it --- or if it's best to leave it for now and home-brew ALL of this up later (if at all).
Issue 4: Pretty far rocks at this point -- I know that the Home Assistant community has an AqualinkD integration to get the pool integrated w/ the rest of the house. Has anyone used this? The Pentair guys seem to have pretty smooth sailing but it seems that Jandy has potentially wandered far enough from the 485 standards to make this difficult? This is pretty far rocks, but if there are things I could do now to ensure a complete functionality later then I would likely do them.
This forum seems fantastic -- I have already learned an incredible amount -- there are some remarkably deep rabbit holes to fall down -- and you guys have some FANTASTIC pools. So thanks for that already!
