AquaLink RS, Pool Service Can't Figure it Out
FYI, your LXI heater is connected to the Aqualink as described in 3.4.2…
I'll check tomorrow morning for what illuminates when the heat comes on, but when the cleaner comes on the SOLAR is lit.
I set it, but this implies there's a function that checks temp @ 9AM and heats, if necessary. Can that be disabled?
You have to show me what lights on your indoor panel in the morning.
I would have expected a schedule in the HEATERS POOL button to enable pool heat at 9AM. Once that button is enabled, as shown by its red LED, then if the water temperature is below the desired set point you just lowered the heater will go on.
What cleaner do you have that runs on a schedule?
If we can’t figure out where POOL HEAT is getting turned on you could go to SYSTEM SETUP - CLEAR MEMORY and start fresh and you program in the way you want it to run.
I don’t think you are missing any mysterious part. Your Aqualink and heater are running fine. Just setup issues.
I assumed the cleaner function pumps water through the Jandy filter, is there something else I'm not aware of?
You said a cleaner runs that turns on SOLAR.
Do you have a pool cleaner that drives around inside the pool?
Do you have an In Floor Cleaning System (IFCS)?
I'm pretty hesitant to do a wipe, I'm obviously pretty green with this system. How many settings need to be specified after a wipe?
I am not suggesting it yet. Just a future option. We would need to fully understand your setup, which I do not yet.
Have you checked every button to see that no others have schedules set?
No, for some reason I thought only the HEATER buttons could be scheduled. "FILTER PUMP" is set to start @ 9AM and runs to 4PM, that's got to be part of the problem. Does this function check for set water temp?
You need FILTER PUMP on and HEATER POOL on to start the heater.
Your heater is starting at 9AM since your FILTER PUMP begins running. But I don't know what is turning on HEATER POOL.
See what LEDs are on after 9AM.
