- Jul 21, 2013
- 65,386
- Plaster
- Pentair Intellichlor IC-60
From
www.troublefreepool.com
Couldn't blow my drain (2 ports in bottom of deep end) out so I got a 6 gallon Ridgid compressor from HD. Plugged up all the drains in the equipment except for the pump, pushed air in thru the pump drain. 15 psi and 2 minutes later I had good bubbles coming out of each. Shut main drain and turned off compressor.
Do we care about air leaking from Jandy valve?
First time closing my pool. I have a Vinyl liner so I'm only draining to about a 1/4 way up the skimmer, builder doesn't want me draining any lower. Blew out the 3 returns with my shop vac, got great bubbles from each and plugged each of them one at a time. Could see small bubbles upon plugging...
