Why is this Teed in like this?
Maybe this is an air line designed to inject air?
I would use a 3" suction and then either a 3" return with a hydraulically balanced design and replace the wall fittings and install a blower line.
Alternatively, you can run each return separately using a 1.5" line from a 3" manifold at the pad and use individual valves on each line so that you can choose which jets to concentrate the flow on.
You would also need a separate 1.5" air line for each return with individual valves so that you can select which returns to send air to.
That is 16 individual 1.5" PVC lines, which is a lot of plumbing, but 1.5" PVC pipe is pretty cheap.
For example, you might choose to only use 4 jets, which will only require about 60 GPM.
Core drill out the existing returns and install venturi jets.
