I have a 1.5 hp air blower for my jacuzzi and wondering how I can make it variable power? Is some kind of dimmer switch instead of the on off power switch an option? I'm pretty sure it's not, but a boy can dream....
Oh yeah, hows that work? Are you diverting the airflow with the valve or something? Or is the valve to blow air out to reduce e pressure on the main air pipe to the jacuzzi?
Depending on the type of motor en the blower you can either use a regular dimmer switch or a VFD.
Easiest way would probably be to control the airflow with a valve though.
