Adjusted alkalinity
Franswois
5
Dallas, TX
Hi all,
Does anyone know the formula for the “adjusted alkalinity” number Leslie’s lists on their tests?
Is it: alkalinity - (cya/3)?
Thanks! Just switching over to TFP so I don’t have my own test kit yet.
Franswois
5
Dallas, TX
Great, thanks!
I am using the pool math app. I figured I needed to reverse Leslie’s adjusted alkalinity before I input it into poolmath because the pool math app is expecting the unadjusted number.
JamesW
23,219
The adjusted alkalinity is the TA - (CYA x cf).
Cf is the correction factor, which is based on the pH.
pH........CF
7.0.......0.22
7.1.......0.24
7.2.......0.26
7.3.......0.28
7.4.......0.30
7.5.......0.32
7.6.......0.33
7.7.......0.34
7.8.......0.35
7.9.......0.36
For example, if the pH = 7.6, TA = 90 and CYA = 70, the adjusted alkalinity is 90 - (70 x 0.33) = 67.
Donldson
4,657
NW Ohio
First: welcome to TFP!
Don't try doing this using Leslie's or any other pool store testing. They aren't reliable and you could end up running in circles, or worse. You want accurate numbers to go on and that means your own testing.
mknauss
36,040
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
You need a proper test kit, see Test Kits Compared. I suggest the TF100. A proper test kit is needed to get the accurate water chemistry results needed to follow the TFP protocols.
Reactions: JamesW
Franswois
5
Dallas, TX
Yep, I’m working on getting a test kit so I can do it myself—just using the pool store numbers until I have it in my hands.
Thanks everyone for the help and support.
Reactions: JamesW
