Moved from here... Pentair/Compool CVA-24T actuator valve problems
having a similar issue... actuator doesn't move - doesn't matter what I turn the switch to, or if I short the limit switches inside. Also tried replacing limit switches since they were so cheap, no luck. The weird thing is... it wasn't working, I took it apart, including the valve to make sure nothing wrong with the valve, then put it back together, and all of a sudden it started working. (this was before changing switches). Then replaced the gaskets on the valve because it was leaking, then stopped working again and it's stuck in the closed mode, no movement at all no matter what I do (other than taking off actuator and moving manually). I will double check voltage coming in, but I don't think that's the issue. Any way to confirm the motor is dead? OR if I take it apart might there be something obvious like busted teeth on the cogs? Just want to triple make sure before I drop what seems now to be $160 for a new actuator, as I was convinced it was just going to be switches. It's probably 6 years old.
