Here are the pictures in the picture it looks Bluer Than what it is it's actually like a milk White that's why I took the one of the skimmer you might be able to see how milk it is in that thank you again
Each tab adds 1.3ppm cya to your water - this steadily increases your cya making your necessary fc level increase - 16 tabs adds 21ppm cya! remove the tab floaters asap.to keep my chlorine at the level between 3:00 and 6:00 I keep 16 tabs of trichloro s traz four tabs in four different floaters
Yes hello once the slam calms down from being all milky looking and I can see the bottom hopefully in Clear Water I will send you a picture of the stains. Thank you again. I'm going to send you a picture of the slam that I did. Can you take a cya reading while you're doing a slam? I figure I need to let this sit at least a couple of days to get clear last time I slammed it took 2 days for it to clear.
Okay now I've read this but I am where I am if you see the other post. I did order the test kit. I guess at this point all I can do is wait for it to clear up so I can see it but the pictures I sent do not do justice they make it look like it's blue it's not it's milk. My liner is 18 years old and has no design on it it is a very light blue almost white in color. That is one of the reasons the stains show up so bad I think but they shouldn't be there at all. I really do appreciate your help.Chaz,
You need to know your actual cya & be able to test fc & cc separately over 10ppm to adequately do the
SLAM Process without risking your liner or equipment & to ensure you not only kill the visible algae but also prove it is gone safely.
Your taylor k2005 should be able to test cya - you just need the reagent & possibly the little squirty bottle if you have lost yours
The test strips have too broad of a range & may lead you to over/under dose wasting chlorine as too little is less effective & too much risks damaging your pool. FC/CYA LevelsR-0013 CYA Reagent (8oz)
tftestkits.net
The k2005 only accurately measures up to 10ppm fc so you’re flying blind right now.
You need the fas/dpd test as it measures fc & cc separately up to 50ppm accurately
FAS/DPD Chlorine Test Kit
tftestkits.net
As mentioned- no floc.
Just the slam process with liquid chlorine.
For a successful SLAM Process
you need to continue to MAINTAIN Slam level fc for your cya as often as possible (multiple times per day is best) until you meet ALL 3 end of slam criteria-
You are done when:
CC is 0.5 or lower;
You pass an Overnight Chlorine Loss Test
AND
The water is clear.
(Crystal Clear w/no algae dead or alive)
*Check & scrub every nook & cranny where algae may hide (light niches, steps, drain covers, ladder handrails, skimmer throats/weirs, abandoned lines, autofill, overflow drains, etc.)
*If water can go there, algae can thrive there.
*Run slam level water through all water features & lines for at least a couple hours a day during the SLAM Process.
*Brush & or vac daily (this breaks up biofilms that algae uses to protect itself from chlorine)
*Backwash/clean filter when pressure rises 25%over clean pressure.
Looking at the chart that you sent for the cya versus slam level my cya with the Taylor test kit that I have with seeing that little black dot at the bottom I did it three times and I kept coming up with between 60 70 which the chart calls for 28 on my FC which of course with the Taylor kit that I have only goes up to 20 but it is so much darker I'm thinking it's above 20 closer to 30. But why is the darn thing so milky?. Again all I'm going to do is wait for 3 Days to see if it clears upOkay now I've read this but I am where I am if you see the other post. I did order the test kit. I guess at this point all I can do is wait for it to clear up so I can see it but the pictures I sent do not do justice they make it look like it's blue it's not it's milk. My liner is 18 years old and has no design on it it is a very light blue almost white in color. That is one of the reasons the stains show up so bad I think but they shouldn't be there at all. I really do appreciate your help.
Don‘t worry about stains now. Once your water is truly clear - no cloudy water, no algae, and you have a handle on keeping it that way, then we can talk about any staining that might be present.Okay now I've read this but I am where I am if you see the other post. I did order the test kit. I guess at this point all I can do is wait for it to clear up so I can see it but the pictures I sent do not do justice they make it look like it's blue it's not it's milk. My liner is 18 years old and has no design on it it is a very light blue almost white in color. That is one of the reasons the stains show up so bad I think but they shouldn't be there at all. I really do appreciate your help.
Yes I'm looking forward to getting that test kit add on to the Taylor test kit I'm using now. I was keeping it between the three and six mark of the free chlorine. That's why I don't understand how I got algae again keeping the chlorine up there. But after the past couple days on here I think the amount of cya I had was canceling out the use of the chlorine. Correct? I think once my FC starts to go down I hope to see why a will go down as well.? At this point I am just going to wait until the free chlorine goes down to about 5 ppm hopefully by then the water will be clear if not I don't know what to do . I will keep you informed. Again thank you for all your help.The milky water is likely algae, especially since you have green in your deep end. And you can’t accurately measure chlorine until you receive the part of the test kit that you are missing.
Have you looked at PoolMath yet? Rather than add a lot of chlorine when you have no idea how much you already have, let it fall until you aren’t at the very top of the color block on the container, then add just enough to stay near the top. That way you have some chlorine in the water, but you aren’t overdoing it.
Don’t add a bunch of other stuff. Just chlorine, until you can accurately test it.
Thank you I will look at that thread. To drain my pool and fill it is not really feasible. I am on a well. And I've never drained a pool before so I don't really know how to do it. But as you said I'll wait till the pool cloudiness is gone / the algae is dead. Then we can go from there. Correct?Exactly, your CYA is high and so it takes a lot more chlorine to be effective. The only way to reduce CYA is to drain water, but don’t panic. Once you can properly test, then we can advise you on the steps you need to take.
Your water won’t be clear until we eliminate the algae, but we’re going to do that, so don’t worry!
While you are waiting, go take a look through the thread I’ve linked below. This is how clear your pool will be if you hang in with us and follow the principles we encourage.
How Clear is TFP Clear?
The cya reading that I'm getting may not be very accurate. With the Taylor test kit I have you use the pool water and then add the region till the black dot goes away the pool water is so cloudy won't that affect my reading? Is there a better kit to test my cya with? And if I need to add more chlorine should I continue to use the granular chlorine that I use to slam or should I use liquid chlorine. If I need to use liquid chlorine what kind should I buy I've never used liquid chlorine before? Thank you so muchWhen your fas/dpd kit arrives you can accurately keep the fc at slam level as often as possible until you pass all 3 end of slam criteria
CC is 0.5 or lower;
AND
The water is clear.
That’s the whole point Shock Level And Maintain = SLAM
You don’t want the fc to fall until you have passed all those criteria. Letting it fall to 5ppm won’t accomplish anything. Keep with slam.
Until then you can attempt to reach slam level but don’t attempt to go over.
Glad to know that you’re able to actually test cya.
That is the most accurate cya test. Your cloudy water will not affect the test results. Be sure to do the test in bright light, outdoors on a sunny day is best.The cya reading that I'm getting may not be very accurate. With the Taylor test kit I have you use the pool water and then add the region till the black dot goes away the pool water is so cloudy won't that affect my reading? Is there a better kit to test my cya with? And if I need to add more chlorine should I continue to use the granular chlorine that I use to slam or should I use liquid chlorine. If I need to use liquid chlorine what kind should I buy I've never used liquid chlorine before? Thank you so much
The circulation might be all right now I only have the one jet in that big of a pool I have a facing a little down and straight across from where it comes out I've also added a sub pump to create more of a whirlpool. But that deep end is always pretty much a dead spot. Any ideas?Liquid chlorine is best right now. And don’t worry, you can work with high CYA, you’ll just require more chlorine.
Why aren’t you getting adequate circulation from your pump?
You may want to consider adding another return closer to the deep end.The circulation might be all right now I only have the one jet in that big of a pool I have a facing a little down and straight across from where it comes out I've also added a sub pump to create more of a whirlpool. But that deep end is always pretty much a dead spot. Any ideas?
