Ratcheting pipe cutter works great. For lots of cuts a circular saw works great with a high tooth count blade like 40 to 60 teeth. Cuts straight. Clean the shards out as you go
I assume I need to SLAM (do I actually need to?), add salt and CYA, and then once those levels are good I can turn on the SWG?
No. That is for high flow rate situations were you might need to bypass some flow.I've seen in Pentair's documentation that they have the SWG installed vertically. Is there a benefit to a vertical installation versus a horizontal one?
Just to make sure I'm following:No reason to SLAM fresh water. Add 5 ppm of FC and 60 PPM of stabilizer/CYA once the pool is filled. Add 3000 ppm of salt and let it dissolve for 24 hours. Then turn on the SWG.
Add 2/3 of your stabilizer and salt and then test after about 3 days. It takes a while for those chemicals to dissolve. Once you know how much more you need for your target youc an add the rest in one or two doses. This way if you don;t have your pool volume perfect you don't overshoot with those chemicals.
Pentair says the recommended salt for the IC40 is 3600 PPM. So, initially add in what I think I need to hit 2400 PPM (2/3 of 3600), measure after 3 days, and adjust as needed? I think Pentair says once I got 2800 PPM it's safe to turn the SWG on.
For CYA I start by adding what I think I need to hit 40 PPM (2/3 of 60) and adjust as needed after 3 days?
