- Mar 8, 2022
- 297
- Vinyl
- Pentair Intellichlor IC-40
After seeing the great work that @duckcmmndr and @jastudee did and are doing with their DIY pool installs, I figured it might be helpful for me to make a post of my own to track my progress and ask any questions as we go through this process. On April 15th, 2022 we ordered a 16'x30' Flat Kidney pool kit from Royal Swimming Pools.
- 42" tall steel walls
- 6' deep end
- Cantilever coping (pool deck will be EP Henry pavers)
- 8' radius sit in step
- Pentair Superflo VST pump
- Pentair 320sqf Clean and Clear Cartridge Filter
- PentairIC20 IC40 Salt Chlorinator
- 2 drains, 2 skimmers, 3 returns
Here is roughly where the pool will be going. I can't move it much more to the right because that is where our well is.
We're hoping this pool location gets enough sunlight. This photo was taken at 3 pm in late September, and our neighbors trees are just starting to shade over the area. We had what branches we could pruned, so hopefully this year there will be a little be less shade, and what shade there is will be less severe and more filtered. With this photo you can also see the shed where the pump, filter, and SWG are going.
I have secured contractors to do the following work:
- Electrician is installing a 50A sub panel in shed that is located close to the pool location.
- Fence Contractor is swapping around the opening orientation of a gate we have, as well as repairing a few sections.
- Arborist pruned some overhanging limbs (as well as other non-pool related work)
- Excavator is awaiting arrival of pool kit to schedule ground breaking
My rough budget for this project currently looks like this:
- Pool Kit - $14.5k
- 55 bags pool base - $1.5k
- Concrete for bond beam - $2k
- Excavation Sub - $3.5k
- Electric Sub - $2.5k
- Fence Sub - $.75k
- Arborist Sub - $1.5k
- Permits - $1k
- Pavers - $5k
Total: $32.5k
I know there will be additional costs that I'm not factoring in such as plumbing and electrical supplies, but for a ballpark I think this was fine. We were originally quoted $45k for a smaller, simpler, and more basic pool installed by a local pool company and they wouldn't be able to install it until June 2023.
My current plan:
- Take off a week of work to get the initial stages completed.
- Excavator Breaks ground for rough excavation
- Finish excavation manually with a shovel and a helping hand or two.
- Set up the walls, getting them as straight and plumb as necessary
- Rough install the two drains at the bottom of the hopper, and run plumbing under panel walls
- Verify walls are straight, plumb, and all dimensions are within specification.
- Get concrete truck with pump truck to pour bond beam
- Finish the rest of the rough plumbing (skimmers, returns, and plumbing to/from pump house)
- Pool Krete the bottom (I'm actually kind of dreading this part, and wondering if I should just try to hire it out)
- Hang liner
- Start filling with water and partially backfill
- Finish plumbing with any liner cutouts needed.
- Wire up electrical to the pumps and run bonding wire around pool, tying in steps and ladder
- Finish backfill
- Take a break, swim in semi-finished pool, stare at pallets full of pavers, contemplate life choices
- Install pavers for pool decking (may hire this part out if budget holds up and/or my back does not)
Some things I still need to do:
- Permits (currently working through this now)
- Purchase a sump pump of sorts (any recommendations?) I'm sure It'll rain at some point and even if it doesn't, I'd rather have this and not need it.
As of today, we have received our liner, and the bulk of the rest of the kit is en-route on a freight truck somewhere. I'll need to rent a forklift for a day (probably next week) to unload it all.
- 6' deep end
- Pentair
- Pool Kit - $14.5k
- Fence Sub - $.75k
- Permits - $1k
- Pavers - $5k
Total: $32.5k
My current plan:
- Hang liner
- Finish backfill
