- May 7, 2014
- 430
- Vinyl
- Hayward Aqua Rite (T-15)
One question I have for folks who have been down this path before is how you went about setting the final, finished grade of the pool deck? This feels crucially important, but so far I've just kind of been eyeballing the slope around my site and thinking about it in my head. My initial thought is to set the top of my pool deck (top of pool + coping + paver height) to be at the same grade as the pad inside the shed that the pump and filter will be installed on. If you look in the photo above it kind of shows how the entire yard slopes gradually down from the shed, so my thought would be that between the shed and the pool I could create a small swale (not really a swale, but just strategic sloping) with pavers that would route any surface rainwater around the pool and then gravity would do its thing and continue to pull it away from the pool. I estimate there's a roughly 2"-3" drop between the middle of the pool site and the top of the shed's concrete pad. I remember reading in some reading from Royal or Pool Warehouse that your finished pool height should be 2" above surrounding area, but I assume that means when you factor in the thickness of your coping and deck material as well?
I had a lot going on in my backyard, I was building a pool house before the pool and had an existing patio and the elevation of all of these were really important because after all was said and done I did not want any drainage issues or have awkward transitions.
It looks like your shed pad is the highest thing in your backyard, so you have to think about that. It also looks like you have an existing patio and you will want to walk seamlessly from the patio to the pool area without an awkward transition. It's really hard to give advice in this area without actually seeing it or having grade elevations. That being said I can give you some things to help you figure it out.
- The pool deck (your pavers) need to slope away from the pool, in all directions, at a rate of 1/8" to 1/4" per foot so rain water wont run into your pool (1/4" is preferred).
- The use of deck drains is a great way to get rid of excess water when you have something sloping away from your house and also away from your pool, sloping towards each other to a central low spot.
- A good laser transit is not required but makes figuring out elevations quick and accurate. It was the 2nd purchase I made after ordering the pool kit.
- You need to establish a location of "known elevation" and do not change it throughout the build. This will be your baseline to work off of in establishing grade for pretty much everything.
I have built lots of stuff over the years and always managed to get by with levels and string levels. I have used a old school transit (requires 2 people), and knew that was a slow process. I knew being down in the hole digging I needed a quick way to determine yes/no for depth so I bought a laser transit kit. I did not want a cheap one that was not going to give me accurate readings. I bought a Bosch GRL400H Self Leveling Rotary System. It is accurate to +/- 3/32" at 100 feet. That may be overkill for a pool...but it is what I landed on. Something like this: Bosch GRL1000-20HVK would be comparable. I am sure you could find a cheaper one or maybe even eBay it. Like I said, it's not required...but it sure makes figuring out what your elevations are quick and accurate. I can't imagine doing a job the scope of what I took on in my backyard without one.
If you look at this picture...you will see a brick (circled). This was my don't move it point. If you continue the grade of my patio at the same slope...you end up at this brick. I knew I needed a deck drain at this location. I based the elevation of the pool house slab and sloped outdoor covered area of the pool house as well as the dig depth of the pool floor off of this brick. So for example if it is 6' from the brick to the pools edge that means I needed to go up 1.5". So at that point I can take off the wall height + coping thickness + concrete deck thickness and know exactly how deep I needed to dig. Same thing to figure out how high the slab for the pool house needed to be so that by the time you slope away from the pool house towards the pool you ended up with a good fall both ways.
Here is the day the deck was poured...you can see the drain in the location the brick once was. I have a 2nd drain between the pool house and pool as well.
I feel like I said a lot and nothing at the same time....I hope this was somewhat helpful.
