Y'all I think we are actually done! I want to formally say a huge THANK YOU to TFP. This site and all of the folks on it have been instrumental in us getting to this point. I know I'm well overdue, but in a couple weeks when my credit card cools off a bit I will absolutely be donating to try and give a little bit back to all of you who have helped me so much.
Winterizing went pretty smoothly. I got a 26 gallon air compressor and that seemed to do well blowing out the lines as best as I can tell. We have fairly mild winters here in south Jersey, and my plumbing is deep so I am not too worried either way. The equipment pad is absolutely dry which was the most important thing to me.I used the NPT drain fitting on the pump instead of blow through plugs with Schrader valves because I figured that would allow for more volume. I also used regular plugs on the returns instead of duckbill ones ones because like
@Newdude said once I saw the duckbill plugs I wasn't convinced they were a great design.
The safety cover is from Tara Pools (same as my liner) and was ordered through Royal Swimming Pools. No lie, this might have been my favorite step in the pool build process, and not even because of the obvious reason that it signified the end. Safety covers are just a cool design and the install process really isn't bad as long as you have the right equipment. I borrowed an SDS-Plus rotary hammer drill and used a $45 1" x 10" Bosch masonry drill bit to drill all 36 holes for the paver pipe anchors. By the last hole the bit was definitely worn down, but probably could have done at least a few more. I didn't decide to test the safety cover, but I'm ecstatic with how it came out. I only broke 1 paver, and it's relatively inconspicuous so I'm not even going to bother replacing it for now.
So, I think that really does mark the end of this build thread for me. At least for the foreseeable future I plan to cut back significantly on the amount of time I'm spending on it. Sometime this winter or in the spring I'll get a topsoil delivery and update y'all how that goes.
Thanks again for all of the advice and I truly appreciate the time anyone has taken to follow this thread. If anyone has any questions I'd be happy to do my best to answer them, it's the least I could do to give back.
