My Zodiac LM2 chlorinator control unit seems to run quite hot the higher it is set. If I put my hand behind the bottom back portion of the unit where the transformer is, I will have to remove it in 5 seconds or so it is that hot. Also, the black connection on the cell heats up about the same. I have checked for loose connections in the control unit and no damage is apparent by looking at it. I suspect it may be the lead from the unit to the cell.
Can anyone with same equipment confirm their units are running at these temperatures?
