Can someone tell me if I have lost my mind? I cannot get my jandy valve to turn so that I can cut off main bottom drain and only have the skimmer pulling water. Is there a trick to this???
Simply remove the screws and rotate the valve to operate the way you want... Or just remove the tabs that prevent you from moving the handle past the stops..
