- Jun 28, 2024
- 6
- Plaster
- Jandy Truclear / Ei
As you see above, tons of white specks in my pool. It’s only visible with the light on. I have a SWG so I assume it’s calcium. I can’t get rid of it. I tried sc-1000 but seemed to make it worse.
I’ve had the problem from the start. Pool was installed Sept 2023. Test results at the end of this post.
The only time I saw improvement was at the end of a SLAM. Once the salt cell went back on they came right back. Not really sure what else to do. Only thing I can think of is to get my salt cell on a separate timer. Any thoughts or suggestions?? Maybe it’s not calcium?
Chlorine: 5.0
Ph: 7.8
TA: 65
Calcium hardness: 350
CYA: 60
Salt: 3,250
CSI: -0.04
Temp: 89
