I live in Florida and got a brandnew 14 gallon saltwater pool with pebbletec finish (midnight blue) around 2 years ago.
I noticed a year later a white scaling everywhere in the pool surface. Assumably it is calcium.
I used a punice stone to manually remove the scaling. It worked but would be far too labor expensive to clean the entire pool that way.
Now in the last few weeks I worked with a pool technician to help me. He made me aware that the pool calcium level is super high with 600ppm. So I drained part of the water and refilled it, calcium is now at 300ppm.
He did an in water acid wash first. It didn’t take any of the scaling off.
Then he tried the jack’s magic product. After using the test kit on the sunbed area, it looked like the green copper and scale stuff would work.
2 weeks into the treatment, none of the scaling came off. The only thing that happened is my total chlorine went sky high up to 14
He also drained the spa, and did a direct acid wash there, most of the scaling came off. But he was concerned that it takes off too much of the surface as some “blue spots” are visible. I think the spa finish now looks like it is supposed to look. On the sunbed, some of the scaling came off too by directly pouring acid there.
After spending a lot of money on chemicals to rebalance the pool after the jacks magic treatment, the water is finally balanced again.
Now looking back, I think the pool had a bad startup as I remember some of the white areas were there early on. Back then I was not that familiar with this, so I didn’t mention it to the builder company. Now I am out of warranty.
I am at a point now where I think the only solution for my pool is an acid wash.
Does anybody have other recommendations or any feedback? Thank You!!
