Cartridge Cleaning Supplement for Biguanide Users
QUESTION:
What should I know about cleaning my cartridge element if I use a biguanide system such as Leisure Time Free or Baquacil?
ANSWER:
Unlike chlorine which oxidizes the bacteria in the water, the active ingredient in biguanide systems, polyhexamethylene biqunaide (PHMB), destroys the bacterial cells.
PHMB locates and binds to the bacterial surfaces, and then attacks the outer bacterial wall.
Once this wall has been compromised, the inner cell membrane (the cytoplasmic membrane) is destroyed.
This destruction allows the cell contents to disperse into their surroundings where they are further broken down into their elemental parts by a non-chlorine oxidizer such as Leisure Time Boost or Baqua Shock®.
In addition, Leisure Time Boost and Baqua Shock are mild coagulants which combine bacterial cells and other small particles in the environment into particles large enough to be trapped by the filter.
The resulting deposit is a gray sticky film on the media which can only be removed with Leisure Time Filter Clean or Baqua Clean.
If trisodium phosphate (TSP) or any TSP type cleaner is used prior to stripping the film, the cleaner and the gray film will combine to form a gum-like substance.
Once this occurs, the substance cannot be removed from the media and the filter cartridge must be replaced.
WARNING: Follow all manufacturer's instructions, warnings and cautions when using Leisure Time Free or Baquacil products.
Leisure Time and Leisure Time Free are registered trademarks of Advantis Technologies, Inc.
https://www.unicelfilters.com/retailers/ci_baquacil_users.asp
