I would suspect many here would say what I'm doing wrong is....using biguanide, n'est-ce pas?you must be doing something wrong;
Uh-huh..and he who laughs last laughs best
If you are not doing anything wrong, then you have no ability to fix the problem.It's not me...no way.
No, you have been saying this for 10 years.You don't believe me?
Ummm..ok...I'll buy that one UNLESS the problem is using biguanide.then you have no ability to fix the problem.
I haven't run into short cycling until the last few.No, you have been saying this for 10 years.
I try not to give up on something till as many avenues as I feel are realistically possible to try to solve a problem have been exhausted. I haven't gotten to that point till this year. I have NO problem with how the water looks and would probably not convert if it weren't for this filter issue. Logic dictates that the next step - to account for a few variables - is to see what happens with chlorine. If it's as troublefree as most report here, fine. I'll go with it UNLESS the filter pressure problem remains. That's what I need to find out since then the only solution would appear to be continually buying new grids for each season, which seems a bit ridiculous.Honestly, I don't really care what you do.
Thanks. I appreciate your reply.The Softswim should be fine. I would not use anything from Baquacil.
Not really...I've been saying for probably close to that long that I DON'T want to convert until trying everything I can to see if I can make baqua work successfully by experimenting with several different chemicals. I don't think there are any other products out there to try that I haven't already UNLESS a different cleaner would be worth it. Thing is, why would the existing cleaner - soft swim or baqua filter cleaner - have worked so well up until the last few seasons? Fresh fill went in back in '14 when the pool was renovated, so perhaps things were going well filtration-wise several years later due to whatever might have been in the old water (algae issue?) that was drained out.you have been saying this for 10 years.
Why? I've always been told it's good to do this at least a few times a season - with biguanide anyway. This is why I asked what it typically done for DE grids with chlorine.Now that's a strange product.
The thing is, by the time I'm done, unless this stuff is invisible to the eye, there would appear to be nothing on those grids, especially after spending over an hour scrubbing each one on both sides. Been using filter cleaner for 22 years with no issues until the last few. Yes, the filter pressure does increase moreso than with chlorine - I was told that from day one when starting to use biguanide - but nothing like these last 3 seasons where sometimes I only get 2-3 days per cycle. The pressure goes up that fast. A baquacil lab technician (as referred to in another thread) mentioned that the grids become "blind" and that the process is irreversible.i don't necessarily think you need a cleaner once you get rid of the Baqua residue from the filter.
Yeah...same here. Never thought about the grids. They just did the job year after year. So, rather unprecedented to have bought 3 new sets of grids in the last 3 years. The brand new set is really only effective during the first season they're used in. The following season results in short cycling. So the change is that...something is either coagulating against and clogging the grids that didn't before OR the grid material is inferior to what it used to be.Never had an issue but needed to replace the grids after 17 years.
Wait...not sure what you mean. Instead of using DE?I was using chlorine and perlite as the medium.
This is what I need to find out and, again, the reason for starting the thread. So it sounds like there is no need for any sort of chemical cleaning of DE grids using chlorine? I could buy into that real quick. One less product - already using Oxidizer, Sanitizer, Algicide, Ahhsome, and Baquacil Line Clean....and filter cleaner. For a few seasons experimented with Aqua Finesse tablets - but all that seemed to do is constantly jack up the pH. Had alot of that stuff left over so sold it on eBay. People snapped it up within a few days.In a Baqua pool I get why it's necessary but what an annoyance.
Yes, I used Aqua Perl which is perlite. It is a fine powder just like DE and seemed to be just as good filtering as DE. It claims to be 1/2 the weight as DE so I bought 12 1/2 lb bags (actually bought it as a 2 pack so 25 lbs) and used the same amount of scoops as DE. When my last AG pool was removed I had 2 unopened boxes and I think another slightly used box in the garage ... I couldn't give it away!Wait...not sure what you mean. Instead of using DE?
You will not need any chemicals or taking VA-52 cartridge apart. I had an identical filter for many years. It required backwashing every 4 - 6 weeks. At the end of the season I just removed the cartridge assembly and hosed it with cold water. The only time I took it apart was when replacing grids with torn fabric.This is what I need to find out and, again, the reason for starting the thread. So it sounds like there is no need for any sort of chemical cleaning of DE grids using chlorine? I could buy into that real quick. One less product - already using Oxidizer, Sanitizer, Algicide, Ahhsome, and Baquacil Line Clean....and filter cleaner. For a few seasons experimented with Aqua Finesse tablets - but all that seemed to do is constantly jack up the pH. Had alot of that stuff left over so sold it on eBay. People snapped it up within a few days.
