Hi everyone,
We are getting ready to sign the contract for our new in ground pool in Austin, TX. Pool is a bit on the smaller size (15' x 20', ~8000G) to keep enough yard space for the kiddos. The PB is strongly recommending the UV + Ozone but lots of reading on TFP has me leaning towards SWG instead. I'm thinking about making some other changes that I've summarized in the table below:
I would like to get your opinion on my changes and if you have any other recommendations. Everything else in the contract looked good to me (2.5" suction, 2" return, #4 rebar, etc). However, I would appreciate an extra set of eyes on the specifications and will attach a copy of that. Project total (pool, patio, and ipe deck) is coming in at $109,229. Is negotiating with PB typical? They seem so busy that I figured negotiating would be difficult to do.
Thanks for all the advice!
Qty | PB Recommended | My Changes |
1 | Pentair 420SQF CLEAN & CLEAR PLUS CARTRIDGE FILTER | Ask about upgrade price to 520. |
1 | PENTAIR Superflo Vs (variable speed) 1.5HP Pump | Upgrade to IntelliFlo 011028 with surge protector. |
1 | Paramount Ultraviolet Water Sanitizer (2 Lamp) | Remove |
1 | CMP/DEL, DEL Ozone, UV-C 50 | Remove |
1 | POWERCLEAN ULTRA VS INLINE Chlorine Tablet FEEDER | Remove |
1 | Poolmiser Automatic Water Leveler | Same |
1 | CMP PRODUCTS Pool Defender WATER BOND SKIMMER | Should we add a 2nd skimmer for redundancy? |
1 | 5GAL MIRAPRIME AQUA-BLOK XL WATER BARRIER (CFP-65-1226) penetrating colloidal silicate liquid primer that integrally waterproofs concrete | Couldn't find much about this. Is it typical to seal / prime the gunite? |
1 | INTELLICENTER i5PS POOL/SPA CONTROL W/O SCG | Don't know why they listed the i5PS instead of the i5P. Will ask to change to the 5PIC60. |
