- Jun 14, 2022
- 46
- Plaster
- Autopilot Digital PPC3 (RC-42)
In the process of converting from my old EasyTouch Upgrade panel to IntelliCenter, I'm confused about the purpose of one of the relays. The relay is run from the SPA output (under the AUX and PUMP outputs on the controller board). The relay Line connection is jumpered from the Filter Pump relay Load side. Presumably, this means the relay is energized and provides 220v to its Load side when the pool is in SPA mode and the Filter Pump is running. The relay load wires seem to run down into one of the PVC conduits exiting the load center and into the ground. I can't for the life of me figure out what this can possibly run.
Our system is a single body (spillway between Spa and Pool) with one main pump and one heater. SPA mode operates the valves to isolate the Spa, and change the temp to the Spa's higher temp setting. The jets run off two separate circuits with their own pumps, and controlled by one of the AUX relays. There are no other features in the Spa to be run off the relay.
Any ideas what this relay connected to SPA mode control might be meant to do?
