Have you made contact with one of the friends of your father to be present on day of gunite. I think you need another impartial set of eyes on this.Unfortunately, my dad isn’t actually part of the gunite crew. He’s a CDL driver who’s responsible for making runs to the quarry to pick up the sand and gravel they used to make the gunite.
Of course, he’s very good friends with all the gunite crews. I almost hired one of them to build my pool, but he’d just started building pools and I didn’t want to hire a completely new outfit. Even so, the same friend has been super helpful with any questions I’ve had since we started with this builder.
I’m sure one of them would come here for me that day, but the problem is they’d likely be shooting pools the same day making that arrangement difficult.
Can you hire a Shotcrete inspector for tomorrow to be an independent consultant of the work being performed?
Either your hole in the ground is ready or gunite or it is not.
I would prepare a checklist and then do an inspection of gunite readiness with the PM or Owner or both. Things don't have to be perfect but have to be good enough.
On your retaining wall - will there be any water features or plumbing in that wall?
- Forms in place
- Proper spacing of rebar and plumbing from forms and soil
- Plumbing in proper places.
- correct lengths
- pipes not bent or under stress
- centered as necessary in design
- Skimmers boxed in with rebar and tied to pool structure
- skimmer mouth properly framed
- skimmer mouth at correct height for water level and tile line
- skimmer properly aligned in all axis
- Lights in proper places
- Light niches protected with covers
- Lights centered as necessary
- Plumbing passes pressure test
Why is the retaining wall connected to the pool structure? I have not gone back through this thread to see if there is a design showing where this wall is. Maybe you can drop it here.
Looking at all the big red flags you posted above will provide your answer on whether to call it off or not.
An irrigation crew doesn't know about pool plumbing. The builder is trying to cheap out and is continuing to do shoddy work.
I guess you don't know until you call him.
If stuff is out of square and not fixed before gunite, it will be out of square after gunite - and be encapsulated in gunite.
Are the walls square or still bowed?
How will they rectify a recently glued plumbing joint that might leak? Do they intend to do another pressure test after gunite is applied?
I cannot see where the outside edges of your bond beam will run and how thick your bond beam will be all around the pool. Usually you can visualize it from the edge of the dirt walls to about 3 inches inside of the rebar and that is the way the gunite will be shot.
Take for example this pic around this skimmer. I drew some colored lines for discussion.
There is a board along the red line. Is that the inside or the outside of the bond beam?
There is a pipe to the left of the red line. Will that be encapsulated by gunite or be outside the bond beam?
Is gunite expected to fill that entire void as outlined by the yellow line?
I would expect the gunite to box the skimmer as shown by the blue line. And there is much less rebar around the skimmer box then what we typically see.
Then how does the yellow line or blue line indicating a wall run into the jumble of rebar at the bottom of the picture?
I don't see how the gunite crew knows how to form the walls based on the layout of the dirt and rebar. Now if they start working they will do something but it may not be what you expect.
And do you have a fixed price for gunite or will you be billed by the truckload? Filling those voids with gunite will run the tab up.
See if you can draw the inside and outside walls of the entire structure based on following the rebar, forms, and dirt. I can't in some areas.
Up until today the builder said they will fill all the voids with gunite, then today he started mentioning back filling with dirt after gunite. The entire structure has moved and eroded so much, but the builder just keeps saying the gunite crew will fix everything.
All of the gunite cost is on the builder, not me.
- That board is supposed to be the back of the bond beam.
- That skimmer line was supposed to be encapsulated by the gunite.
If you end up going forward with the gunite tomorrow I would meet with the foreman of the gunite crew before they start. Walk the entire site with him and discuss EXACTLY how he will handle every wall. If he is comfortable doing it as you discuss then maybe let it rip.
I think there is a good chance the gunite foreman will shake his head and say can't be done.
My worry is when a builder is on a money losing job he is going to start cutting quality in other areas to make up for it.
Is this inside the pool or outside the pool?
Looks like outside the pool so why is this rebar running past the edges of the pool?
And how will the gunite be formed in this area?
Back of the bond beam meaning outside edge?
But that pipe is outside of the board so how will it be encapsulated?
If you or the PM/Builder cannot tell the gunite crew exactly what you expect them to do they are going to make up their own surprises on how they fix it.
