If the returns and main drains are capped basically all pipes are still capped from pressure testing I'd say you're safe as long as the pressure testing never involved water.
Ah, you beat me to it. I've never seen this done, but my question would have been: did they pressure test with water, or air? If the pipes are only filled with air, then the OP should be fine.If the returns and main drains are capped basically all pipes are still capped from pressure testing I'd say you're safe as long as the pressure testing never involved water.
Seems like they should be tested under the conditions they'll be used. But are they ever tested with air? I thought I read about that here once.All pool plumbing should be tested with water, air is not useful for pressure testing.
The pressure test was done with water.
Since everything is sealed/capped, I’d imagine it’ll be hard to blow out the plumbing lines.
I started to type something similar earlier, that the builder should be involved. And he should be. He really should be handling all of this, as he is ultimately responsible for all aspects of the build at this point, including weather damage and/or mitigation.Ask the builder what to do.
If you use absolute temperature and pressure, you can figure out the formula to see the expected change in pressure when using air for a pressure test.Temperature can affect the air pressure, so you have to take the temperature into consideration.
