- Feb 6, 2015
- 7,834
- Plaster
- CircuPool RJ-45 Plus
On the return side - I've seen an actuator on the pool return/spa return valve. The one pool I saw with automation had a separate pump for the spa jets.
In your configuration, I guess adding another actuator on the non-automated valve would be needed. Then you can set up a spillway circuit. And you'd need to set up a couple other circuits to turn on the spa jet valve.
Got a recent pic of the equipment pad showing the valves? (I'm too lazy to look thru 13 pages of this post)
