Every winter I:
1. Turn off "solar" heat option on indoor panel for pool and spa (Intellitouch)
2. Unplug a connector that says "solar" on the circuit board in outside panel ("pool guy" said that was right)
3. Remove end cap on roof at lowest point to drain roof.
When I do this the system runs with no water coming out the open pipe (where I removed cap) so I assumed I stop flow to the solar.
BUT
I have to have a gutter replaced due to a slow leak from a pressure relief valve that pooled pool water in the sagging gutter and rusted it. I cut the two pipes to the roof and despite following above steps water was flowing from both pipes when pool pump came on.
What the heck?
Bob
BUT
What the heck?
Bob
