Water feature not cascading fully
Ellie1050
6
Massachusetts
Do you have any ideas why my water feature isn’t fully cascading, rather the water is coming out in spikes. Thank you!
Water Features - Broken Waterfall Stream
If you have gaps in the waterfall stream then debris has lodged in the opening of the waterfall or water flow is too low.
Use a credit card or similar object and gently position it inside the opening while the waterfall is on. Slide it along the opening to the point where the debris is located and gently pull the debris through the opening. Do not use a metal tool.
If there is no debris in the opening then clean the filter and filter basket and check the position of the flow valve to the feature.
Reactions: Ellie1050
Does the water go through the filter or is it on a separate pump with no filter?
If the water is not filtered, the problem will continue.
Mine was on the filter and it still happened on a regular basis.
I'm still mad Allen remined me no metal, use plastic. I had a plastic putty knife just for this.....
CMP make a filter to pit inline with the water feature...
