To begin with, we have a somewhat rigged set up for our inground pool filter. The underground pipe from the sand filter that sends the filtered water back into the pool is broken. Rather than breaking up the concrete to replace it, we have it rigged with a large hose that leads from the filter back into the pool (placed over the side of the pool and tied to the ladder) to circulate the water. It has worked well for years this way; we just take the hose out of the pool when the filter is not in use so no one trips on it. The other day, with the filter completely off (and having been off for at least a solid day) we removed the hose from the pool as usual, and water kept coming through as though the filter was on. We didn't realize it for a bit, thinking that water was perhaps just draining from the filter... a few hours later, the water level had dropped drastically, almost below the skimmer. We were able to stop it by putting the winter plug into the skimmer - but clearly this is not a long-term fix. What could be causing water to pull through the skimmer like this when the pool filter is completely off?
