My system is set up such that under Pool and Spa there is a Toggle for Heater Off or Heater On. The only issue is when I turn the Pool on, the SWCG kicks on.....I have a feature called 'Pool Flow' that I use to just circulate water. How do can I also toggle heater on or off with the pump running but without the SWCG? If that makes any sense. Seems like there has to be a way to make a feature 'Heater' and when you turn it on the pool pump also turns on but I can't seem to figure it out. Thanks!!
