I just upgraded to a variable speed pump that is pre-programmed to run at different speeds throughout the day. I have a Hayward H250ED2 gas heater thst was here when I bought the house 15 years ago. When the pump runs at less than full speed, the heater bangs loudly and vibrates so much that I end up turning it off -- which means I can only run the heater when I am home and can turn the pump to full speed. Any ideas on how to deal with this? I suppose I need a way to have the heater turn off when the pump is running at low speed.
I have an electric heat-pump heater that I may install next year to replace the gas heater. Would that heater have the same problem?
