We are new pool owners and just put up a 15 foot round vinyl pool that holds about 4400 gals. Tried using strips for a few weeks, but just switched to a kit to test water. Have been able to keep Chlorine good (using float with tablets) around 2 to 3, Ph seems to look good at 7.6, but alkalinity is very high, in the high 300s. Have read a lot on the forums about lowering alkalinity and using aeration to keep pH from dropping too far. Have put between 3-5 oz of ph down (dry powder) in each day for past 5 days and Ph has stayed same and alkalinity has come down (started around 400, and now at 360). Haven't performed any aeration since the pH hasn't really lowered.
Wanted to see if this is a course to continue on with adding ph down, or if there's a different direction to go.
Also, haven't put any stabilizer in pool yet since we didn't want to complicate the process until we had most everything balanced.
Appreciate any guidance. Thanks
