Dave,
You absolutely may be correct.
But so far that is not my experience. I have 1.5 hp motor in this family/class which has "B" insulation. No buzz up and down from 15 Hz to 60 Hz. No vibration.
Pools are in a clean low dust and grime to stick to the motor so one should not be too concerned about heat dissipation since there is nothing holding heat onto the motor casing. Easy to put a sun shade above it if it is in full sun.
VFD is programmed to not go lower than 15 hertz, and even then only when backwashing/rinse cycle for a few minutes. Normal rate is around 30 hertz and 60 at cleaning.
Have you heard of someone with a motor in this range 0.5 to 1.5 hp that has had this problem? I have not, or i just have not looked in the correct place.
