- Sep 20, 2024
- 20
- Vinyl
- Intex Krystal Clear
Finally got the pool up but the spray handle was stuck on the hose so I put oil on it which didn’t help but got oil all over the patio slab
. So I cut the handle off and by the time the ladder was built the water was four inches high. Spent the rest of the day siphoning water out with cups because there was not enough pressure to push out through the hose.
Any way, I’m confused about the legs. I know they need to be straight and level, but how far away from the liner? Right now there’s a few inch gap and not sure if they’re placed correctly. Will the pool fill and push out the legs? I don’t see on the instructions where to place the legs and once it’s filled, I don’t want to have to drain again
I am burying four inch deep pavers under the legs as well. At what point do I dig under the legs to place the pavers?
Any help or encouragement would be deeply appreciated.
One more thing, has anyone found a way to use a ramp or wide stairs for their large dogs? I have no deck but want to rig something for Fido to get in and out.
Spent over two months digging out the land theand putting up a retaining wall (built it three times before we got it right). We’ve had over two weeks of 90 degree weather and no pool. I’m discouraged. Feels like I’m starting over again, there are a couple of uneven spots when I put the level horizontally on the top of the frame. The water level looked even though from inside.
