Was that maybe the day after you cleaned the filter? A clean filter tends to allow much better water flow.
The picture in post 54 was right after I cleaned the filter, the next day it was at 140, so yes the day after I cleaned the filter.
Did you do a SLAM Process or try and treat any algae between the filter clean and now?
As much as you think the filter is clean the first place to look with a low flow problem is the filter.
I would backwash the filter, dump the DE, and charge it with new DE.
I was talking to an installer from the pool supply store (I know, stop rolling your eyes. That's why I'm asking here LOL) He said that even with liquid chlorine (and I can't remember what he called it exactly) the something solids (he used three letters) raise in your pool and the only way to get rid of them was through dilution. What is this he's talking about, in all my reading, here and other places, I have never ran across this. He wanted to sell the park an auto liquid chlorinator with sensors that test the water and when it drops adds the right amount of chlorine. Sounded good till he said the unit was $1,600 and that didn't include installation. Yikes!!! Needless to say we're still looking LOL
I imagine he was talking about TDS. It does not mean anything in that form. We only concern ourselves with some of the components, like calcium, salt, CYA, etc.
You do not want an ORP system which is what he was selling. They are not reliable and take significant maintenance.
Also I was looking at the filter and pump setup the other day, and there is a Hayward progrid DE separation tank model C9002SEP, I suppose I should have cleaned this when I cleaned the filter, reading the label on the tank (which I had to take pictures of to do because it's against the wall), and looking up the manual for it, it says it should be cleaned every time the filter is backwashed. My questions are. I am assuming I just wash it out like I did the filter? Do I need to put extra DE in for this or just clean it out? what is the purpose of it?
Just clean it out. The tank captures the dirty DE so you can environmentally dispose it. It filters out the dirty DE from the water. Where does the water output from the tank go? Back to the pool or waste?
Liquid chlorine adds salt. That is the only 'dissolved solid' that it adds. And salt is a non factor for your chemistry values.
You can test for calcium in your water with your kit.
I have no information on the DE separation tank. Search the forum to see what you come up with.
Impressive. I’d backwash and add the correct amount of de to your filter now.
