I recently have been maintaining, or trying to, a mobile home community pool. I have only maintained a private back yard pool of mine before. A few days ago the county health department closed the pool citing unsafe chlorine levels (easy enough to take care of just added some chlorine), and high Cyanuric acid (119, the county requires it to be under 100). After doing some research, and talking to the pool guys at my local pool store, I found out what CYA was and the only way to reduce it was through dilution. The guy at the pool store suggested a 2/3 drain and refill. After draining and refilling, I skimmed the pool and let the filter run over night, I took in a fresh water sample this morning and the CYA was 128 which is higher than it was before. I just wanted to get another opinion. he now suggests I pour in a gallon of acid let the pump run over night scrub the walls and bottom of the pool, drain completely and start from scratch. He says that the CYA has absorbed into the plaster and coated the pipes and that's why the CYA went up, stating the water was saturated and when the clean water was put in it basically sucked it out of the plaster and pipes.
The pool was replastered a year ago this month. I wasn't the one that set the pool up for this season and wasn't involved with the setup and curing process of the replaster. We use chlorine granules (which I just recently learned contain stabilizer), having to over chlorinate especially during the hot days in So Cal.
What would you guys suggest I do?
The pool is a rectangular 25,000 Gal, IG, Plaster, DE Filter, Pentar FNS Plus, Water is just city spigot water.
