I took a test sample to the sparkle brite pool store today and they said I had no cya so I put in 8 cups granulated directly into the skimmer the pool is 10,000 gallons I removed the basket and poured it in I have algie but I haven’t put in any chlorine or added the 4 cups of muriatic acid I was told to put in because in the last few days I’ve added about 4 to 5 cups already my ph is 7.8 chlorine is zero calcium is 180 and alkaline is 150 according to them.
I bought a pool master 6 in one test kit when I test it my self I got zero chlorine and ph is 7.8 and not dropping next I tested the alkalinity I ended up dropping between 20 and 22 drops to see a color change according to the acid demand chart I needed to add a pint I believe of muriatic acid so I did next day tested it again I ended up somewhere between 24 to 25 drops in the last phase of the alkalinity test. I did this for 3 days each day the drop count went up so I went to the pool store I was given the instructions above.
I don’t know if I should add the muriatic acid because my readings were off compared to the pool store I’m currently waiting for my hth 6 test kit so I can test it my self I got 260 and they said my alkalinity was at 130 the first time I went up there this last time they said it was at 150 this is when I learned that my cya was zero.
When should I put in yellow stuff for algie, muriatic acid and chlorine? I know it takes about 3 days for the cya to fully desolve and another week for it to show up on a test but my pool is being consumed by algae and I don’t know what else to do also my pool surface is plaster if that matters and I’m in Florida I don’t have a backwash option on my pump and have no idea how to drain it if I had to hope I gave enough information thanks in advance
