My pump recently died and it was replaced with a Pentair VST pump. Previously everything was connected to a mechanical timer that turned everything on/off. The installer said since the new pump has its own timer I didn't need to use the mechanical timer anymore and he removed the on/off screws, so now everything is powered all the time.
The problem with this is that I noticed the TruClear SWG says 'Chlorinating' all the time, for some reason the flow detector isn't shutting it off properly.
I called Jandy and they said my options were to either go back to using the mechanical timer, and set the timer to the same time that the VST pump is on (would this cause any issues for the pump? )
or replace the mechanical timer with a TCX, he said it was a digital timer that would fit inside the same housing as the mechanical timer. Seems like that would be the way to go, but the only thing I found was a Aqualink TCX automation system, not sure what exactly I would need.
Any help/ideas would be appreciated. Right now I am just turning the SWG on/off manually every day.
