Great. Just checking as FC above 10 ppm effect the pH test.
Assume the pH is 8.2. Use Poolmath ( you will need a current TA test result) and add acid to lower the pH to 7.4. Add the acid, circulate/brush the pool, test the pH 30 minutes later. If still not in the 7's, repeat adding acid, etc.
