This may not be a technical issue, it may just be the way I'm reading it. Above you stated
I pour in a heaping blue scoop of powder, it turns dark pink, I hold the r-0871 bottle vertically over the tube and count drops, then I put in 5 drops r-0003 and if it doesn't remain clear I put in more drops r-0871 until clear.
As we know, adding the R-003 drops is only to record your CC.
So I want to make sure that for your FC test, you are only adding the R-0870 power, then the R-0871 drops. Once it goes from pink to clear, take that number and divide by two - DONE. Correct?
Okay, now here's the other thing, and I personally did the same thing. No kidding I went through TWO full bottles of drops until another expert got me back on track. Here it is .... "More is not always better". By that I mean that if your SLAM FC is 16, try not to go higher than that for your first bedtime OCLT test. That's because our FC is designed to acclimate (bond) with a specific amount of CYA in the water. Even though there is no sun at night, going too far over your CYA-designed FC level can still lead to excessive FC loss - even in the dark. It happened to me for several days in a row. The very first time I let my FC come down to the exact FC SLAM level, I passed because there was no "excess" FC that couldn't bind to the CYA. I remember those nights/mornings all too well.
In your case, 1 or 2 drops is everything.
Maybe tonight, try a bedtime FC of 18, verify it after you've added bleach and the sun is down. Then hopefully tomorrow morning it will be very close. Besides pulling water from the same place as you have already been doing, keep the pump on the same speed. BY the way, I'm a GVEC customer too, so low speed is fine if you have it.
Let's try that and see how it goes tomorrow.
Oh, and just so you know ... when I couldn't pass my SLAM, because my CYA was at 70, so I was supposed to maintain an FC of 28, but I was going over to something like 34-35. I needed a calculator to count my drops. Ugh.
