Could it be Diver Dave? He's been in the pool at shock level for hours on end. And still can't pass OCLT, but I had a setback. Wednesday night when I went to add bleach for the night I was out, thought I had another box of bleach. I didn't go buy more so by the time I got home from work Thursday my FC was down to 8. I got it back up to shock level about 4:30pm yesterday and brushed everything. Pool was still crystal clear. I didn't check OCLT this morning due to my boo boo yesterday. But will try it again tonight.
NEW PROBLEM - possibly what's been effecting my OCLT not passing? So when I have to backwash and go thru the filter settings I'm not by the return when I switch back to filter. But earlier I noticed that when I turned it back on filter I could see a plume entering the pool thru the return for about 30 seconds, then it was clear. When I backwash - I turn off the pump, switch the multiport to backwash, turn pump back on low and watch the clear tube for it to run clear (generally takes a couple minutes). Then I turn off pump, switch multiport to rinse, turn pump back on low and repeat watching for the clear tube to run clear (generally takes a minute or so) . Then I turn off pump, switch multiport back to filter, turn pump back on high. When I noticed the plume I turned off the pump and got a black sock and held it over the return but the plume went right thru the sock and the sock didn't catch anything. However, even if something is reentering the pool, wouldn't it be dead by now from being at shock level for weeks? UGH. No idea what to check on the filter. Thoughts???
