In early December I had my pool pump replaced. The new one is supposed to be similar to the last, it is a Jandy Flopro 1.5 single speed pump. I had a huge electric bill recently and the next one is gonna be as bad, I have been going nuts over all my other usage, which is quite frugal, when I remembered something the pump installer did/told me. He tested my freeze protection by placing the wire/lead (I'm sorry IDK what it's called) in ice water. My wire is contained within the metal unit, not external to the air, if that makes sense. He said because of this I need to have my temp set higher, which does make some sense, but he set it at 40! So even tho the winter has so far been mild here in N Texas I am sure that there were nights my pump was running all night when it didn't need to. The best I can figure is my pump uses about 1.84kwh. My electricity was running about 12 cents an hour, I just got a better plan so it will be better but...! I went out and reset it to 36 but I thought I'd ask you all what you do. Of course I don't want the pump to not kick in during a freeze but I cannot afford these bills. FYI I am also running it for 4 hours a day right now. Thanks for any advice!
