CALL IN THE WANGER!!!
I was wondering where the Wanger was in all this, now that you mention it.
I was wondering where the Wanger was in all this, now that you mention it.![]()
I'm curious, having had to reshape a footing when I got an engineer involved for my two- and three-story deck project...
With all that weight, I was surprised to see such a small foot print. Is that because of the proximity to the pool? I think I had to do 2' x 2' if I remember right. And why so deep? Does that have something to do with shear?
Why couldn't you have shallower and wider footings for those two farther from the pool, and eliminate some digging by doing so?
I've never heard of Hydro vac excavation. Sounds cool. I was picturing myself trying to dig a 5' hole with a post hole digger and a shop vac! Ha, knowing me, for $2500, I'd probably try that anyway!! I need the exercise!![]()
Well, I was just expecting to replace a few rotted boards on my decks. I found one rail post that was almost hollow!! You know how it goes. That turned into a complete tear out, a red tag, $1200 worth of permits requiring another $800 worth of engineering! For existing decks!! I have to admit, though, that they made me build 'em better than I would have, so I'm glad now that it's done and paid for. I lucked out in that my engineer was able to pick up a lot of what I had already done, so I didn't have to redo much.
Most of that was just county money grabbing. The final inspection took place from my front porch. He never did go up on either deck. They got their money, the inspection was just a formality...
At least your engineer found a way to get you what you wanted.
I've been wanting to ask... why those big bases around the posts? Is that structural or cosmetic? Seems like a lot of space taken up...
Can you take care of your shear requirements by using a wide flange between posts with welded moment connections at the top of your posts instead of relying on your footings?
Ah that sucks. Variance? Play sympathy card based on your previous due diligence and "was told I was good to go" factor?
If they stick it to you, does that kill the entire project? Or what half would you lose?
B! All of that for a spider gasket?? DUDE! You are the king of over kill
So can't you "share" the findings you got in the beginning with the brat saying nope now?
