Thanks, I guess the instructions that came with it were good cause I did what was in the video. OK here are my first results and reading the numbers I think I have to drain some of the pool. Ill probably run the tests one more time just in case I made a mistake but please feel free to let me know your thoughts.
1. The FC test I did twice and got similar numbers. First one was 16 and second one was 20.
2. CC test was 2 on the first one and 3 on the second one.
3. T100 test. This was odd and I am not sure if the chemical is bad or not. The PH was around 7.2 but the Chlorine/Bromine the water turned orange
4. The calcium was 250 ppm
5. The TA was 140
6. The CYA was around 100. I have a defective view tube as everything was dripping out.
5. The TA was 140
