How about "Round up to next highest gradation"Well "gradation closest to fill level" does not follow TFP methods and can result in setting your FC lower then recommended.
I like the color coding!
I have something similar in a spreadsheet but never thought o print it out since I have the laminated card that came with my kit. I LIKE!
Round to the greater number line? I need to simmer on this wordingRound to the higher number line
How is salt measured? Its not in my TF100 kit, but I'll be happy to modify this reference guideSalt-Orange... You need to add salt!
Can you make this a PDF as it is easier to print and file. Thanks for doing thisYou Fishes! Your thread got me motivated and liberally plagiarized your reference card to update my own reference that I had on a spread sheet. I like your concept and I'll probably laminate a copy and leave it in my test kit. Even though I now have them all memorized I realized if I have someone else do the tests they can reference the card in a jiffy!
Fantastic! If you move the Salt column to the left of TA, you level up visually since it's more consistent with a rainbowYou Fishes! Your thread got me motivated and liberally plagiarized your reference card to update my own reference that I had on a spread sheet. I like your concept and I'll probably laminate a copy and leave it in my test kit. Even though I now have them all memorized I realized if I have someone else do the tests they can reference the card in a jiffy!
I arranged them by the frequency I do the tests.. I used the colors of the bottle lids/stickers instead of the Pool Math app. It made more sense to me that way. I started adding tid-bits of information to the sheet from the tips and tricks I read about here and so it recently sprouted a notes section.Fantastic! If you move the Salt column to the left of TA, you level up visually since it's more consistent with a rainbow![]()
I'll work up a PDF version. The other side of the card had the CYA chart, Recommended levels for my pool, And other useful things so if I am out at the pool and have a questions I don't have to run back in the house and log in to TFP, or pull up it up on my phone when my hands are wet.Can you make this a PDF as it is easier to print and file. Thanks for doing this
