- May 3, 2014
- 62,852
- Fiberglass
- Pentair Intellichlor IC-40
And what's the advantage of VS? Also, is the volute and pump housing refers to the same component?Superflo VS - variable speed. I would not put in another single speed.
Ok. How much HP should I be looking for? My current whsiperflo is 2HP.In today's pumps, the volute and pump housing are the same.
VS allows you to run at lower RPM and thus lower electrical usage. The smaller VS will work fine for the pool as you do not use the spa. As of July 19, 2021, you will not be able to purchase a motor greater than 1.1 THP for a pool pump that is NOT variable speed.
Yes I use liquid chlorine.Again, without needing to run the spa as designed, the 1.5 hp VS would work just fine. Most use would be at lower RPM.
You do not show a Salt Water Chlorine Generator, so I assume you add liquid chlorine on a daily basis for chlorination purposes.
The controller upgrade will be expensive. Does FEMA covers these pool repair costs?Unsure on the controller. I have heard of upgrading the Compool LX3800 but nothing on the LX100
Like I said, you will be getting a VS motor eventually. Up to you on when you upgrade.
I doubt it. Homeowners insurance does not cover them.Does FEMA covers these pool repair costs?
No.Will it affect the performance/efficiency of the pump at all?
