Hi!
Part R-0872 is the FAS-DPD titrating reagent for bromine. (
FAS-DPD Titrating Reagent (for bromine)). Instructions for use with DPD powder are as follows:
1. Rinse and fill sample tube to desired mark with
water to be tested.
NOTE: For 1 drop = 0.5 ppm, use 25 mL sample.
For 1 drop = 1.25 ppm, use 10 mL sample.
2. Add 2 dippers R-0870 DPD Powder. Swirl until
dissolved. Sample will turn pink if bromine is
present.
NOTE: If pink color disappears, add R-0870 DPD
Powder until color turns pink.
3. Add R-0872 FAS-DPD Titrating Reagent (bromine) dropwise,
swirling and counting after each drop, until color
changes from pink to colorless. Always hold bottle
in vertical position.
4. Multiply drops in Step 3 by drop equivalence (Step 1).
Record as parts per million (ppm) total bromine.
