- May 3, 2014
- 58,690
- Fiberglass
- Pentair Intellichlor IC-40
Taylor Pool n Spa Water Chemistry..CYA test should be done in bright sunshine.
Extended Test Kit Directions Archives
www.troublefreepool.com
What test kit do you have?
That is a TA of 70 if you are using a 25ml sample. Have you checked the pH?It took 7 drops of the R-0009 to go to red.
That's good. Correct?
The R-0013 is for testing Cyanuric Acid. Are there instructions and a test block with your kit with a little dot on the bottom of the test tube? Can you perform the test during daylight hours and post your result? If you are over 70 or 80 you will need to drain and replace some water...And I can't find a number on this test kit anywhere. Except inside the lid where instructions are.. #2004B
It has 3 each of yellow red green and blue bottles...and one white one of R-0013.
A waterproof book of detailed instructions...for science whiz kids...and a Watergram Water Balance Calculator.
